| Re: roll cage pictures please Randy,
I have done a few swing out upper door bars..
Dean Lampe has run his...he is a tall chap like you....
Maye he will share his thoughts....
We make the cage from 1 1/5 inch .120 wall DOM as an RCR is under 2500lbs as specified by SCCA.....obviously for a full SCCA legal cage we need to add more tubes and change the config. but for open track/lapping days no upper bar is required.
Depending upon car weight larger diameter tubing may well be required..
RCR-40..Mk1, 2 and Mk4
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF www.RACECARREPLICAS.COM www.superlitecars.com |
