Originally Posted by gt40pinhd just got a quote from them yesterday.
seemed pretty good. now...
he quoted me 5 to 6 weeks. guess i'll have to ask how accurate that number is. also ask about his quality.
any other company worth checking into?
thanks for the info,
wes |
Just an FYI, I had posted this on another thread regarding T&L
"I too ordered a 347 stroker with Webers from T&L, unfortunately my experience hasn't been that good. I order mine in December 2006, after 16 weeks it was finally ready, however they built it on the wrong block..!! There seems to be a lack of communications within the company and a high turnover of staff. They ended up doing a rebuild with the right block but that took another 12 weeks. When the engine was finally delivered it was missing the water pump, which on the quote was included. I called Lloyd at T&L and asked that he ship a water pump...he never did. Countless calls and leaving messages got me no where. In the end I purchased a pump and we put the engine in the car. Then the next problem appeared, a significant coolant leak from the timing cover. Tried calling Lloyd again, I eventually got through and asked if he could call Bill Andrews regarding the leak, over two weeks went by and no call. I started calling Lloyd every morning until he finally picked up the phone. He is supposedly calling Bill today...we'll see.
After searching other forums I found I'm not the first to have problems and probably won't be the last. If you buy a canned package and you don't mind waiting they are probably OK. If you want something specific they might not be the best way to go. If you have any issues don't expect them to get resolved very quickly. It's been 10 months since I originally ordered the engine and I still don't have anything that runs. If I were to do it again I'd pick a builder that was in closer proximity, one that I could grab by the throat if necessary.
Would I recommend T&L.....at this point.....no."
The final outcome was that the timing cover was poorly manufactured and had to be replaced. Lloyd stated that they pressure test the cooling systems, but if they had they would have found the leak....and it wasn't just a trickle it was pouring out. Anyway they did replace the timing cover and all is well so far, but the engine has only been fired up for a few seconds. Now I'm thinking I should check out the top end and see if anything else is a miss...!!
