You can do allot with the factory valve covers. They are cast much thicker than almost any aftermarket valve cover and can be easily modified. I'm using Comp Cams stainless roller rockers, and the only thing I had to do was remove the baffle. It wasn't needed, as I changed the configuration. I have "several" hours of polishing in these.
