Old 12-28-07, 05:05 AM   #134 (permalink)
Russ Noble's Avatar
Russ Noble
New Zealand
GT40: Building scratc
Re: Kiwi scratchbuilt
Today I have finally fitted up the 928 front mounted starter and assembled the flywheel/clutch/ring gear and offered up the transaxle and set final clearances on the hydraulic release bearing. Everything's going to work a treat. Photos later.
Billet side plate for the 930 has been machined so everything is slowly taking shape. Stick on tags on the original are XY co-ordinates for the hole centres for the mill. Saves doing a drawing, just take a photo.
Russ
