| Re: Fuel Tank crossover / equalizer With the big cross over pipe don't forget to run an air bleed pipe too or when you fill the tanks the one without the filler is going to not fill to well with a bib "air bubble" above the fue;l level
Also suggestion if you go this route make the working cap opposite to your driving seat - it will save problems when you pull up to the pump and cannot open your door as you are too close to the pump (yes I did it once)
