Old 12-31-07, 10:32 AM   #102 (permalink)
CESLAW
3 Tenths
Rep Power: 5 CESLAW is a glorious beacon of light
Re: Chuck and Ryan's RCR Build
Jonathan:
Thanks for the tip. I will check that out.
How did you route your shift cables?
Does your tranny have the reverse detent? When I unscrewed the detent I found that the spring and ball that should have been inside were missing. I am trying to figure out whether it will go into reverse and fifth gear without it and if its sole function is to prevent an inadvertant shift from 5th to reverse.
Chuck
CESLAW is offline   Reply With Quote
