Old 01-02-08, 01:16 AM   #3 (permalink)
PeteT
GT40: none
Rep Power: 3 PeteT is on a distinguished road
Re: Porsche 924 transaxle
The 924 transaxle is based on the AUDI 088. The only good thing is the early unit (76-77.5) has a 3.44 ring and pinion. I have thought about what it would take to extend the pinion shaft so 5th gear could be used. Then it could be used in the 016 box. I haven't come across one yet.
The Porsche transaxles do not have a provision for the slave cylinder and do not have pilot bearing diameter machined onto the input shaft. I guess this could be done but you would need to use a bearing instead of a bushing because the machined end would not be hardened.
PeteT is offline   Reply With Quote
