Steering Lock Stop
How are you guys sorting out your steering lock stop? Any pics would help. At the moment I have the tyres rubbing hard up against the bodywork on full lock. Thanks.
Brian Magee
Hi Murray
I made some split spacers to go inside each end of the rack on Maxiboys car. I think I waisted the centre section of the spacer and fitted a hoseclip round it. Let me know if you need more info.
Brian.
Murray
I always use a split collar inside the rack ends...you can find them in metric and inch sizes, and they can be bored to suit your rack shaft diameter..usually I use aluminum as it is a bit softer and easily sized. Check any industrial supply and you will find them.
Phil
Brian, Phil and Julian, many thanks for your input, the answer is totally different than what I had in mind, I envisioned a physical stop on the moving parts of the hub carrier or something, see daft as a brush!! :pepper:
This makes much more sense!!
Here are the pictures
