| Re: Flexible conduit for door lock wiring. on my GTD, the builder had used a Renault (I think) door connect system - two mating plugs with bulkhead fittings and rubber sleeving - ok so you have to get it from a breakers and use the wiring colours that are pre-installed - but its designed for the job.
__________________ RS built GTD+
Engineering Manager, trying desperately to find out how these things work! |
