| Re: Working for the Dark side...!!!! I know that the arms on this particular car are the "t1" production upgrades ones with higher durometer bushings...so are more than up to the task...
But I do agree with your other comments.
Another thing that is strange is the front upper arm mounts are turned 90deg from stock and make suspension adjustments almost impossible without making a slot , this then required the nut and bolt clamping force to do all the work..and maintainalignment.... not ideal in the least.
RCR-40..Mk1, 2 and Mk4
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF www.RACECARREPLICAS.COM www.superlitecars.com |
