Old 01-07-08, 09:19 PM   #21 (permalink)
Solofast
Rep Power: 1 Solofast is on a distinguished road
Re: Working for the Dark side...!!!!
Originally Posted by Grant B View Post
The factory C5 (and I think C6 as well) bushings aren't really up to the task of tracking a ~3100lb street car on decent rubber (you get alignment shifts). They might be ok on a ~2300lb GTM, but I'd think an upgrade to VB&P's poly-graphite bushings would in order for any GTM build.
I agree that the control arm bushings on the C5/6 are most certainly a weak point (don't ask how I know, been there done that). On the upper control arms they shift so that the arm extrudes toward the front of the car and on the rear they allow the lower arm to go aft. Also agree that the T1 bushings (you have to buy the control arms, they don't sell bushings separately) are better and typically solve that issue. If anybody out there is using C5 control arms it is something that needs to be fixed if you are doing serious track work or you will end up losing caster and grip... For a street car it's probably not much of an issue, but sticky tires really exacerbate the problem.
If you are designing your own mounting, you can turn around the upper rear bushing and readjust your mounting points and if it is installed backwards it won't shift.
Solofast is offline   Reply With Quote
