| Re: GTD wiring loom. Quote:
Originally Posted by CraigB I just got an adaptor from Goffy's bulbs in the UK http://www.norbsa02.freeuk.com/goffybulbs.htm
He does a resin adaptor that lets a P43t H4 (normal H4 bulb) to be fitted into an older P45t headlamp. At £3.50 per side I decided to risk a set  (listed in red toward the bottom of the page I think) | I have those in mine - they work a treat. Still very little visibility in dipped beam, but I think that is a physical constraint of the recessed headlights, the angle of "dipping" and the close proximity to ground. But main beam seem to be fine. I think in conjunction with driving lamps to "extend" the dipped beam distance - should be fine.
__________________ RS built GTD+
Engineering Manager, trying desperately to find out how these things work!
