Old 01-09-08, 01:28 AM   #1 (permalink)
svsgt1
Guest
Posts: n/a
Exclamation LS1 to Audi 01E Adapter COMPLETE!
Hey guys, I forgot to post pictures of this when I finished it a while back. But anyway the adapter and everything else is done for the Chevy LS1 to Audi 01E conversion. It is a 1" thick adapter plate made of aluminum. It uses a stock LS1 starter, flat LS1 flexplate, stock Audi flywheel, stock Audi clutch, and stock Audi slave cylinder. The cool part is that it also uses the stock LS1 pilot bearing as apparently the T56 and 01E have the same shaft diameter at that point. Anyway, the other custom piece is basically what mounts/spaces everything together inside which also aligns the gearbox input shaft and holds the pilot bearing. It is a pretty simple design and everything went together perfectly the first time. I should be firing the unit in the next 2-3 weeks when I get it back from the exhaust shop to fix the mistakes the guy made. Anyway, I hope you guys enjoy. Sorry for not having pictures of the internals as I didn't take pictures of those when I made them.
Thanks,
Adam
Name:	Engine and Trans Rear.jpg
ID:	26399  Click image for larger version
Name:	Shifter and Cable Mount.jpg
