| swap 944S2 pinion and ring 083F in 951 gearbox 016R help Hello:
I want to swap the Porshce 944 S2 pinion and ring (083F gearbox) in my 951 gerabox (016R with LSD). It is a race car used in tracks and I want to get less maximun speed, and my question is if it is possible and enough strong to hold the torque and if it is possible to fit the LSD with the 083F pinion and ring. The ratios are 8:27 in 951 Turbo and 8:31 in 944 S2.
The problem is that I donīt know if the pinion is the same and if I can fit the 951 gears that are strenghthen with the 038F pinion and ring
Can anybody help me with this?
Thank you very much in advance
