Old 01-15-08, 12:57 AM   #5 (permalink)
PeteT
GT40: none
Rep Power: 3 PeteT is on a distinguished road
Re: swap 944S2 pinion and ring 083F in 951 gearbox 016R help
You don't need to do any machining the case. The S2 gears will go in as a replacement. The case is the same as the 951 (turbo) including the wider gear so a spacer is not required either way. You can swap the ring and pinions between each transaxle without any modifications.
PeteT is offline   Reply With Quote
