Thread: Norfolk Tornado
Old 01-18-08, 07:33 AM   #1 (permalink)
saxoncross's Avatar
saxoncross
GT40: Tornado
Rep Power: 3 saxoncross is on a distinguished road
Norfolk Tornado
Well it’s time to formally start my build log for my Tornado. I’ve had a great deal of information & inspiration out of these builds logs, so it’s time I started mine.
The car was purchased as a part built kit, which effectively is little more than a rolling chassis, but has a 4.6Ltr Range Rover V8 engine installed and is mated to a Renault 21 turbo transmission. However, I prefer the idea of having the correct 'small block' 302 engine. I could swap it later, but it would mean re-doing most of the engine installation, manifolds etc, so I’ve now purchased a stripped 302 engine out of a ’74 Falcon and this is now the plan of attack.
As I had to fabricate new mounts from scratch, I wanted to get the engine mounted as low as possible. Using a bell-housing on loan from Chris Cole (many thanks Chris), I managed to work out where the engine & transmission needed to be and fabricate new engine & transmission mounts. I could have dropped the assembly even lower, but I didn’t fancy redesigning the lower wishbones.
I’m planning to use a 8” deep Moroso oil pan and this will be level with the bottom of the chassis. In fact the lowest part of the car is now the bell-housing, which I will end up machining back. When the pan arrives, I’ll be able to work out where the new engine bay cross-member will fit
I believe that this exercise has resulted in the engine/trans being dropped 40mm compared to a standard Tornado chassis, whilst keeping the crank centre-line parallel to the ground.
I also found out that the mounts on the Renault transmission are not symmetrical about the gearbox centreline, there is about 20mm difference and explains why the alignment never looks right.
Gearshift mechanism next.....
Andy
ID:	26546  Click image for larger version
ID:	26547  Click image for larger version
ID:	26548  Click image for larger version
ID:	26549  Click image for larger version
saxoncross is offline   Reply With Quote
