Originally Posted by john_douglass Randy,
My KVA has CV joints on the transaxle side of the drive shafts and U-joints on the suspension side. It uses Corvette rear suspension . I've been trying for a number of months to eliminate a drive train vibration that occurs when I'm accelerating in 2nd gear from about 2K to 4K RPM. Someone else suggested that this combination might be the cause but I was not immediately convinced because the KVA's were designed by legendary GT40 engineer Kevin Atwell - I assumed he would have been aware of such a harmonic vibration.
In you judgment, would a design such as my KVA's introduce vibration or would the combination CV/U-joint combination cancel out any harmonic vibration?
John  |
John- to eliminate the halfshafts in this example- note the road speeds from 2k>4k in 2nd gear. Now in 3rd gear thru the same road speeds is the vibration present to a lesser degree, if so then your halfshafts are probably the cause.
Jac Mac
