Old 01-26-08, 07:37 PM   #89 (permalink)
A-tomic's Avatar
A-tomic
Silver Supporter
Canada
GT40: B-16
Rep Power: 3 A-tomic has a spectacular aura about
Re: Garage - What features would you select?
Look's like it will be a fare size Ron. I could live with it. I would add some turbine vents for the summer to keep the air moving in the attic and don't skimp on the insulation. The less your heat pump has to work the lower the cost and the cooler in the summer. One more thing to have are the car dollies that go under each wheel. Cars that are not used much can be moved around by hand and you can store them in tight areas to free up the space you use most.
Dave
A-tomic is offline   Reply With Quote
