| Re: Garage - What features would you select? Ron,
I don't understand how the tiles can work out but, many use them ( doesn't water run off from wet car or even condensate drain from A/C ,oil, ect seep between the cracks or into the open mesh of some types and accumulate under the tiles causing dirt and mildew build up?
Well due to that concern when I built the new garage 8 yrs ago went with Benj Moore industrial epoxy and as you can see from pics below after lots of engine, tranny, suspension work to the Cobra over the yrs the floor just needs a sweep or quick wash and it's clean. I do use plywood under jack stands and cardboard if a major job but, no real day to day precautions.
Steve P2125 |
