| Re: Garage - What features would you select? That's a Hayabusa. Doesn't see much action during the winter. I've put more miles on it moving it around in the shop while trying to organize. LOL. Another thing is insulation. I don't have any on the walls. I've found having the windows open gives good venting but when the sun is beating on the sheet metal it radiates in and can get pretty hot if you happen to be near the walls. Then in the winter it gets pretty cold. I went too small with the gas heater. It's only a 30,000 BTU unit. Just enough to get luke- warm. I will add insulation then take a look at the heater situation to see if I'll need to go bigger.
Pete |
