Old 01-28-08, 08:13 AM   #17 (permalink)
Eric Martin
GT40: none now, planning one
Rep Power: 6 Eric Martin is on a distinguished road
Re: SBF What transaxle?
Originally Posted by loctite View Post
It should mount up just like the kits for the sbc. A little tail heavy but everyone I've talked to with this swap sez its really not a problem. I just found a kit on the tci site. Has the flexplate, adapter and all hardware to mount a ford to a chevy trans. This looks like what i have been looking for.
The Toronado/Eldorado drivetrain has been used in kit cars for some time. It is very heavy and puts the engine too high and actually has more weight behind the axle line than in front. I have spoken to several people with this installation and they all said it is very tail heavy and the handling suffers alot. Using the SBF would help with the excess weight but you still have the high mounted motor with its high CG and the rear weight bias. Some Lambo builders have turned this around and moved the differential, and flipped it, to get the weight more to the front.
Eric Martin is offline   Reply With Quote
