| Re: LOLA T70 scratch build... Hi Marcus,
The main difference between the Cherry Max rivets and solid driven rivets is fatigue life and clamp up. The driven rivets swell in the hole for a "tighter" more solid fit. I would use them wherever you have access. Cherry does make a fastener that provides some clamp but it is not a direct substitution for a driven rivet. Having said that I think you will be fine for the application you are talking about. Make sure the grip length is correct and find a pneumatic installation tool. For the rivets you have access to you might consider a rivet squeezer as this will assure a uniform installation with no distortion or shanking. You can also install rivets quietly by yourself with a squeezer. As far as the angles, if you are using 6061 you can make hardwood dies and form the angles in a press without drilling any holes. Having said that, I don't think you will have any problems with the duct you are making but if you have any areas that are structural I would recommend forming the angle. Your work looks good, I can't wait to see the finished product.
Steve |
