Old 02-03-08, 01:24 PM   #5 (permalink)
Russ Noble's Avatar
Russ Noble
New Zealand
GT40: Building scratc
Re: Top harness mountings.
Originally Posted by Doug68 View Post
Hi All,
The intention is to put top-hat bosses into the horizontal tube and bolt up the eye bolt through that.
On the downside this leaves the threads taking all the applied load in a prang, which I'm not sure is a good idea?
I wouldn't worry about that Doug, you're bound to have a lot more thread engaged than you would have with just a nut on the back.
I'm sure you'll die from internal injuries caused by the belts long before the threads pull out of either system
Keep up the great work.
