| Re: Removing the roll pins in the ZF cross shaft So Bill: is the problem that the shaft is in but you don't have the shaft to case bearings and the inner nylon bushings in ...so you need to remove the shaft to properly assemble?
If so justr remove as advised above and reassemble with same pins ...You will be OK
Steve |
