Old 02-05-08, 10:34 PM   #6 (permalink)
jac mac's Avatar
jac mac
New Zealand
Rep Power: 19 jac mac has much to be proud ofjac mac has much to be proud of
Re: Intake Plenum for a 260Z
Ron, Put the carbs in the plenum as well so they reference the same pressure should you be careful enough to find a spot for the K/N Filter that gets a bit of pressure. Make the lid removable to service carbs as well.
P.S.-- A large rocker cover off a truck or older six cyl can be used as an airbox-flat plate/sheet alloy onto carbs with provision to screw the cover onto the alloy plate. Extend the plate & cover in front of the carbs so large inlet tube can be connected for cold/ram air.
