Old 02-07-08, 04:28 AM   #4 (permalink)
Chris Melia's Avatar
GT40: England Suffolk
Rep Power: 24 Chris Melia is a glorious beacon of light
Re: RBT transmission: 6 or 7 bolt? Need help
Hi
it looks like it should fit, if you are running the trans inverted for the GT 40. You will also need the smaller 117 tooth flywheel with this bellhousing and either a double or triple plate clutch for 440hp plus.
Take a look at the ZFQ / ZF bellhousing thread, the centre bottom hole is redundant for monocoque's and it takes the standard Ford flywheel and clutch.
Proposed new ZFQ/ZF Ford/Chevy Bellhousing
regards
Chris.
Chris Melia is offline   Reply With Quote
