| Battery to loom sequence Hi Guys,
I know that this will seem quite basic to most of you but a sparky I am not so forgive me. With the KVA I picked up there was a "new looking" loom. Most of it is labelled so I can work that all out apart from the 2 areas that I wondered if anyone knew about. Area 1
At the front end, near the fuse box there are 4 wires grouped together, Solid Blue, Red, White & black. All of the headlamp wires are there so they cant be that but this is the only part of the loom that has no "male" connector to help me as to where it goes. Area 2
I would like to get some help on the wiring sequence from the battery positive to the loom. At the moment there is no obvious way to get power to it.
I attach a couple of pictures, one of which you can see the mystical connector which has no where to go & the other a general picture in case you can identify whose loom it is? Tornado?
Any help for a wiring novice would be grateful. |
