| Re: High Performance Starters Hmmm...
I've helped a couple of cars get past this kind of issue by just cleaning up the electrical system - sounds like you've already covered those bases..
There are other hot-start gotchas as well..
* Valve clearance hot is too tight. Not enough compression to get them to light off at normal cranking speeds..
* The age old vapor lock in the fuel pump - normal cranking speed is not fast enough to push the air out of the pump and start moving fuel. I'm sure you've got that covered too with an electric pump.
Back to starters for a minute..
It's my experience that the gear reduction starters don't really spin the engine over any faster than the standard direct drive starters - just that they draw less current.
If you put a booster-pack on your car when it's hot, and it starts, you may have a lack of amp hour capacity in the battery.. Even if the car is spinning over quickly - try putting a booster pack on as well and just see if it makes a difference.. |
