Old 02-11-08, 08:09 AM   #8 (permalink)
Dimi's Avatar
Dimi
GT40: DRB Chassis 68
Rep Power: 5 Dimi will become famous soon enough
Re: G50 Gearbox Oil Level
Originally Posted by CraigW View Post
Dimi, just grabbed this info that Lynn L posted some time back.
"It seems that best way to get it at the right level, is to pull (or loosen) one of the output flanges and fill until the oil leaks out of the opening. (retorque to 19-22 ft.lbs. for '72+) This will get enough oil in the gearbox to adequately oil the diff gears/clutches (the ring gear will dip into the oil and spray the pinion at much lower levels.)"
It looks like your level is higher than that from the photo.
Not sure of the consequences of this.
Craig
Even going by the above quote from Lynn L if the box is filled up to the level Lynn suggests this would mean the box is holding 5 Litres as shown by the sight tube.
Remembering that the flange shaft where it enters the box is higher than the bottom edge of the flange that the driveshaft is bolted to.
Dimi
Dimi is offline   Reply With Quote
