Old 02-17-08, 02:47 PM   #1 (permalink)
Big-Foot's Avatar
Big-Foot
Gold Supporter
GT40: Replica
Rep Power: 19 Big-Foot has a brilliant futureBig-Foot has a brilliant futureBig-Foot has a brilliant future
G50 Competition Transaxle Support
Hi Guys,
Since my car will see track use and performance driving instruction - I decided that I would like to see some additional support to the transaxle over the 4 - 10mm studs that are used to mount the transaxle.
For normal or spirited driving, this type of support would most likely be overkill - but true to form - I over engineer everything..
Below are a couple of pictures to give you an idea of the mounting system.
The struts are 13" long 3/8" Swedge tubes with Rod-Ends (Heims) at either end.
The main bracket is made from 3/16" thick mild steel.
The lower heim brackets made from 1/8" mild steel.
The upper brackets were purchased from RCR - They are the angle clevis' used on the RCR40 Lower control arms.
If you visit my website:
http://www.GT-Forty.com
and then click on the link to the Competition Trans Support
You can see the steps I went through to create this support system.
From most everything I've seen of the various manufacturers - this mounting system should be able to be used in most manufacturers cars.
Here's a direct link to the page;
GT-FORTY.COM
Lots more pictures on the website.. I hope they help someone out there..
Regards - Randy
