Old 02-18-08, 01:05 AM   #38 (permalink)
CESLAW
3 Tenths
Rep Power: 6 CESLAW is a glorious beacon of light
Re: Cooling System - Excess Pressure
Canton makes a 2 quart aluminum tank with a sight tube. #80-201. I was debating about either the 24 ounce size (80-206) or the 2 quart. Sounds like the 2 quart would be better.
Does anyone have any experience with either of these reservoirs?
Location: Obviously the expansion tank needs to be mounted as high as possible but I assume that the reservoir can be mounted lower. It would be hard to find a high spot large enough for a two quart reservoir in addition to the expansion tank. I was contemplating finding a spot at the aft end near the transmission, where there is a bit more space.
Will this work?
Here is the Canton page:
http://www.cantonracingproducts.com/...atch_tanks.htm
CESLAW is offline   Reply With Quote
