Thread: Norfolk Tornado
Old 02-19-08, 10:40 AM   #12 (permalink)
saxoncross's Avatar
saxoncross
GT40: Tornado
Rep Power: 2 saxoncross is on a distinguished road
Re: Norfolk Tornado
I’ve been working on the steering & geometry over the last couple of weeks. As I’m not using the standard Tornado rack I wanted to check that the bump-steer would be correct. The rack mounts were cut off and lowered, so I could pack them pack up to the corrected height.
The alignment was checked by with a laser spirit-level attached to the front hub, which was over tightened to stop it rotating. The laser image was projected onto a vertical surface, with a sheet of paper attached. As the suspension was jacked up the red dot was plotted on the paper. It seemed a very simplistic way of doing it, but it gave very good results. In fact the further away you move the paper, the more accurate the results get.
The intermediate coupling I’m using is from a Renault and incorporates a collapsible section and a damper and I modified it to fit onto the Ford steering spline. I’m a bit concerned that the damper my clash with the pedals, but that’s another hurdle yet to overcome.
Andy
saxoncross is offline   Reply With Quote
