Old 02-19-08, 12:33 PM   #2 (permalink)
aero's Avatar
aero
3 Tenths
GT40: Currently designing scratch built mid engine sports car.
Rep Power: 8 aero will become famous soon enough
Re: Audi Quattro diff
Sorry - I don't understand the question. Are you asking if it's alright to turn the input in the opposite direction so the output turns correctly, or your situation is one where if you hook it up right now, the outputs will turn in the wrong direction and what can you do about it?
Either way - if you hook it up right now the way the drive train is layed out and the outputs spin in the wrong direction, then flip the whole unit over. Doing this will not only spin the outputs in the opposite (correct) direction, but the ring & pinion will still mesh the same. The big issue is lubrication. You will have to take a best guess as to if it can work and how much lube, then try it and keep tabs on it.
Currently designing a sports car:
Mid engine (what else is there?)
Audi 3.6 V8. (ok, there are others)
40" high (what else is there?)
aero is offline   Reply With Quote
