| Re: In search of advice! At last !! Someone is looking at a realistic estimate of the true cost !
There are lots of figures quoted around the traps (particularly the "rolling chassis" setups - mostly under $40k) - all designed to suck you in.
BUT, when you rigorously add in all the extras, you are starting to look at more like $90k - $110k (and that is assuming that you do ALL the labour).
I did all the labour on my DRB except the EFI wiring, exhaust, final paint, & 2 x engine builds : I reckon it now owes me around $130k in terms of actual money spent. If I then factor in almost every spare minute of my time for 3 years, the estimate of around $200k from DRB starts to look fairly good.
Another "BUT" - be very wary of going with a "turnkey" car here in Oz. Some states here (NSW & VIC) are getting a bit picky over the definition of an ICV (Individually Constructed Vehicle) - you may need to prove that YOU were the actual builder - not DRB or RF or RCR.
So, my advice would be to :
- Take Trevor Booth's advice & pay some dollars to the most reputable engineer in your state. He will be able to give you the good oil on the definition of an ICV, what engines will automatically meet the emissions criteria (& until when), & what other mods might be required for rego.
- Armed with that info, talk to DRB / RF / RCR (Craig W) about how their offerings will stack up against the above.
- Ask more questions of those brave (foolhardy) souls who've been there
- Bite the bullet & sign a cheque
- Fasten seat belts - you are in for one big fun ride !!!!
PS : Some of the above might seem a bit negative - but after you & the car have been "processed" by the system & pop out the other side, you will have :
a) Won the battle
b) Have the best car on the planet
c) Feel soooo good !
Kind Regards,
Peter D.
__________________ DRB (GT40 Australia) #27
331 Windsor / GD-50
8-Stack EFI / Autronic
Dark Metallic Blue Pearl |
