Old 02-20-08, 06:34 PM   #86 (permalink)
Scott Calabro's Avatar
Scott Calabro
GT40: TS40 # 875
Re: Tornado TS40 #875
Hey Brian,
No worries, we can run to the packie for cold ones with 875 while we wrench on your car!
Here is tonight's episode;
Cut hole for left fuel tank quantity sender.
Finished drilling both FWD sill top rivet holes.
Drilled small triangle plates to close cockpit.
Finish drilled both aft sill tops in engine compartment.
Mocked up oil cooler, just for kicks.
Mocked up dual pumps and filters , located and drilled pump mounting holes and fuel feed bulkhead fittings.
Layed out possible storage box modification aft of pumps.
The dotted line represents the storage compartment below the pumps.
S
ID:	27468   Click image for larger version
ID:	27469   Click image for larger version
ID:	27470   Click image for larger version
Scott Calabro is offline   Reply With Quote
