Originally Posted by RamboLambo Hey Russ, could you do me a favour please. Can you measure the outside and inside diameter of the clutch disks and the outside diameter of the 4-spider setup.
Bruce |
Sure Bruce,
The clutch driven discs are o/d 88.1; spline major diam. 48.0; minor diam 43.8;
Clutch drive discs o/d 87.8; i/d 49.0; o/d of the four drive lugs 102.0;
4 spider setup o/d of thrust plates (spider carrier) 90.0;length of spider cross shafts 88.7; o/d of the four thrust plate drive lugs 102.1.
Hope that gives you everything you want.
Cheers,
Russ
