| Re: cable shifter Chuck,
Re Martin's comment on Dennis' cable shift....Dennis revised the original cable shift design to a better performing shifter...I believe it was Dennis' car with the revised cable shift mech that Martin is referring to when he says that it was as good as a rod change ( so if you have the original and are not happy there may be improvement possible).On my car Dennis designed a LH center ROD shift that is great...Not easy install but possible...Pics in the SPF Forum under post "2125 home" or something like that.
Re Dimi's leading edge door cap...I too might fab something like that... I have asked Dimi to post more to add to the "How To" forum...Hopefully he will.
Re Door weatherstripping I ref'd ...You should post to Frank Catt and see if he can either supply or ref you to someone in your area that will handle...Frank is owner and fabricator renown of Wealden Engineering in the UK
Re your Dynamat application and "closing off openings"...Are you going to post pics and a short write up that can be posted in the "How TO" ? Your post should prove valuable to others.
Regards, Steve |
