Hi all,
is it possible to use the original Porsche speedo pickup in a hall effect speedo setup? Does it work this way or some bespoke German method?
This is a quote from the 930 workshop manual concerning testing the pickup. After the cockup with the release bearing I did the bloke thing and found an instruction book
With 1 wheel locked the diff will rotate at 1/2 speed is that correct? so the speedo should be set to an 8 pulse per wheel rotation setting? or am I reading it the wrong way around?
Disconnect the flat male plugs at the connector in the tunnel and connect a test buzzer to the wires leading back. Lift the car at rear axle and turn right wheel by hand. Lock left rear wheel. The buzzer must sound off 8 times for each two revolutions of the wheel. If not replace the sensor.
The left rear wheel need not be locked, if the car is equipped with a Limited Slip Differential. In this case the buzzer sounds off 8 times for each one revolution.
