| Re: Tornado TS40 #875 Scott, is that insulation on your bulkhead panel? If so could you tell us what you are using? I have Dynamat around the tub and footwell but don't want to expose the material to the engine heat on that panel as I am sure the rubber backing will melt into a horrible black goo.
Keep up the great work
Brian
__________________ ...GTD-40
...LHD-LHS
...302 Roller Block
...R-21
...BRM Pin Drive wheels
...Gulf livery |
