Old 03-02-08, 11:26 AM   #2 (permalink)
2124's Avatar
2124
5 Tenths
GT40: Rescue, CA
Rep Power: 10 2124 is a glorious beacon of light
Re: Engine braking (good or bad)
IMO, engine braking was good back in the days when the brakes were marginal - it has no place in todays car.
The only reason to shift down while braking is so that you are in the corect gear when the time comes to accelerate. Blipping the throttle to match revs is done for one reason only - and that is so that you don't cause the rear tires to break traction when you down shift into the lower gear and let the clutch out....remember the rear tires will be lightly loaded under braking making this a very real possibility.
CAV #80, 331 Keith Craft, RBT Swift DB5
2124 is offline   Reply With Quote
