| Re: Engine braking (good or bad) Bad, pulls big end of rod out of shape, wipes out bearings. Not so likely on high quality rods but a real problem on OE rods. If you or the driver reckons the car stops quicker by using engine braking or down shifting you have got the brake balance wrong. Cure-- fix the balance & get another driver, less expensive than the new motor. |
