| Re: Weber 48 IDA - Show me your linkages By increasing the weber linkage from 30mm to 40mm the maximum difference between the two carb levers is 1.6 degrees at 1/2 throttle, note minimal change at zero and full throttle.
How close is close enough??????
Andy
__________________ replica mono chassis
original rear clip
1966 289
48IDA's
This month its going to be red
'This car you have to be measured for...' |
