Originally Posted by EGLITOM The gear box in my chart is from the 2,7TDI as of 2005. but some of your ratios above are similar. If you look close to my chart, you will see that the first gear is a 3.5 and the 3.88 you are talking about is the ring and pinion ratio. So donīt compare and interchange those two ratios
TOM |
I have taked to a swedis gearbox rebuilder..
and he will build a 01E gearbox with this ratio for me..
Pinion ratio 4:11
1 gear:3.5 I think maby it is possible to have 3.3?
2 gear:1.88
3 gear:1.3
4 gear:1.034
5 gear:0.857,
6 gear:0.71
This is the chart how it will be with 275-55-15 wheels
1/3.5..39 Mph (3.3..41 Mph) 2/1.88........73 Mph 3/1.32......103 Mph 4/1.034....132 Mph 5/0.857....159 Mph 6/0.71......192 Mph
And they put a oilpump in the gearbox that spray oil on the pinon also..=)
and the first gear is uppdated from the -99 year wide flexibal gear
what do you think about this?
/Dogge
