| Re: GTD 2 piece wheel gaskets? Eric, Image did originally use a thin gasket between the two halves of the wheel, but have long stopped useing it in favour of a silicone joint compound both between the parts and as Tony says covering the joint on the inside of the wheel. The thin gasket was always problematical and sometimes allowed corrosion to start on the aluminium. Frank |
