Old 03-08-08, 09:28 AM   #8 (permalink)
550spydr's Avatar
550spydr
2 Tenths
GT40: GTD
Rep Power: 5 550spydr has a spectacular aura about
Re: GTD 2 piece wheel gaskets?
Phil,
I'm not certain if they are Comps or not. The car was built in the USA, but I have found that a lot of the parts are sourced from the UK. For instance the disc brakes look to be UK derived and the bolt circle of the wheels is an odd spacing (120mm).
Last night I torqued the wheel halve bolts down and have applied the silicone adhesive sealant material as advised. This evening when I get home from work, I'll fill it up and see how it goes.
Thanks all !
Eric Johnson
550spydr is offline   Reply With Quote
