Rear suspension advice
Hi I am rebuilding my T70 replica replacing the gearbox/rear suspension. This means re-designing the lower rear suspension it is currently reverse a arm with a trailing arm. I have changed the rear uprights to alloy Ultima uprights which means i can no longer mount the trailing arm to the upright (see original setup picture) as it will obstruct the rear wheels.
I was thinking of adding a brace to the a-arm and mounting the trailing arm to the side of the a-arm the mounting points to the chassis would remain the same(see proposed setup picture) but a friend of mine who rebuilds race cars did not like the idea.
The pictures are not accurate they are just to outline the origial/proposed setup.
I know there is a wealth of knowledge and experience on the forum and would value your feedback. Thanks in advance Mark
Russ Noble
Hi Mark,
Apart from introducing side loads into the RJ's on the upright, I can't see any downsides to this. You may have to replace the RJ's more frequently due to increased loads and wear. The RJ's here are probably 1/2 " so should be able to take the extra loads OK IMHO.
The other option would be to space the wheels out. Just a matter of what's easiest.
Cheers,
Hi Mark
I don't see any probs with that at all. Just makes it exactly the same as a real T70 Spider:), and there's no problems with them....
Good Luck
Darren
CRC Racecar Engineering
Hey Mark
I would second what Russ and Darren said...just make sure that your thru-bolt in the bottom of the upright is grade 8, or the metric equivalent.
Phil
Russ thanks for the feedback would struggle to space the wheels. Darren i have a cut away of the first T70 spider the arm seems to go to the upright but it is difficult to tell, had to pull out my tamiya 3B kit at 1 in the morning and you are spot on thanks. Phil thanks for the comments. I have attached an image of some rear "measuring up" I will get a full build site underway soon to show the rebuild.
(sorry can't upload images at the moment will try and add picture later!!!)
Pictures
I will be picking up my Lola Spyder replica in 2 weeks. Can you please post more pictures of your Lola so I can get more ideas on how to finish my car.
Berst regards
John
