Old 03-10-08, 02:46 PM   #12 (permalink)
Series8217
Rep Power: 1 Series8217 is on a distinguished road
Re: Aeroquip Socketless hose and fittings
Originally Posted by Gordon Levy View Post
I really don't see a need for the band clamps but I do use them. Most sanctioning bodies have an issue if you don't use band clamps.
I found this thread while searching for Aeroquip hose dealers.
I would hate to see one of yoru GT40s go up in flames.. Aeroquip warns to NEVER use clamps on Aeroquip Socketless hose because it damages the soft hose liner and can cause the hose to split. Build safe cars, guys!
Here's a quote from aeroquip's site:
Originally Posted by aeroquip.com
Q: Should I use a clamp with the FBV (SOCKETLESSTM) hose and fittings?
A: No. In fact, the use of a clamp has been known to cause premature hose failure at the point of the fitting. This hose and fitting are designed and manufactured to work to the indicated specifications without a socket or clamp.
Eaton Aeroquip - Performance Products: Technical Information
Series8217 is offline   Reply With Quote
