| Eibach springs I would like to replace my actual GTD standard suspension (with Spax adjustables) by Eibach springs as follows (I received this info from Andrew Fordyce at the time):
Front 7" 400 lbs.Main spring, 60mm diameter
3.85" 250/625 lbs. Progressive rate tender spring
Rear 6" 500lbs.Main spring, 60mm diameter
4.6" 360/850 lbs.Progressive rate tender spring
And would like to place Koni dampers.
Is there anyone who could help me to have the right Koni part number?
Tx
Fred |
