Old 03-17-08, 07:49 PM   #12 (permalink)
gt40fran's Avatar
gt40fran
Sponsoring Vendor
GT40: Michigan,USA
Rep Power: 41 gt40fran has a brilliant futuregt40fran has a brilliant futuregt40fran has a brilliant future
Re: Who's got an RCR40 in the UK?
Arnie ..
nice informative post...I will attempt to answer your issues and questions....some of which you will no doubt not agree with but you are a newbie after all...and an open top car driver to boot.,
I have done this and have a big problem getting my 5"11 94kgs of average shaped British bloke into the car. Considering I regularly get into a Caterham with a full cage without a problem, I'm tending to blame the car, not me. Just like Clarkson....how can you there is no alarm system in an RCR40...
I'm pretty certain all the cars currently in the UK without a full cage, have the older roll cage which is behind the rear bulkhead....the standard car still comes with a 4 point roll bar and rear legs mounted behind the bulkhead.
Mr Lowe's recent delivery may be the exception however. The new cars coming out now no longer use this design as the ends of the shoulder straps of the harnesses pass through the engine bay, so in the event of an engine bay fire..... Personally, I'd like to think I'd notice....not if you were unconscious.
So all new cars with a roll bar as opposed to a cage, inherit the rear section of the full cage....incorrect, see above
Now the problem. Because the seat back is essentially a flat panel with side bolsters, reclining the seat (which incidently means you have to move the seat forward) means you cannot curve your spine into the back of your seat to get a comfortable neck, if you want to sit low. Your head is tilted very much downwards to compensate. If you have a chin (or several) like mine, this means your chin is on your chest, so its even hard to talk. This is not at all comfortable...but it is an inherent part of having a car with a roof and it only being 40 1/2 inches tall...dont forget your Caterham is not a Coupe
To exacerbate things more, your skull is also now just a very short distance from the horizontal bracing of the rear cage section, which in the event of a rear end shunt is a very significant hazzard. Of course if you use cage padding it will help, but without a helmet this is still possibly going to knock you unconcious....so would hitting the rear bulkhead with no cage at all....???
And you need to sit low if you ahve the full cage....you need to sit low period..its a GT40
The full cage, as you are most likely aware, has a tube which runs just inside the top of the windscreen and I found that for a proper driving position unless you can get even lower still in the seat (meaning recline the back) this bar intereferes with your vision in a bad way. If you have sever sat in a Cerbera, the effect is about twice as bad as that.....the cure for this is to spec your car with no inner roof panel and have the cage nest closer to the outer skin...which is an extra cost option should you feel the need......just ask....but you will sacrifice a finished inner roof panel...trade off???..
Effectively, as the bar across the top of the screen is not a particularly close profile to the top of the screen, you have to set your eye level around 2" lower in the car to compensate...bear in mind that original GT40's have no roll bar...at all
This, in my opinion is the biggest flaw of the RCR, and this is a key reason I have restrained myself from placing my deposit with Fran....with the dollar/pound rate being so favourable you could have a custom cage made and meet any and all your criteria...and still be on the upside.
Fran of course has some photos of 6'8" people who own RCR's so I am making a mountain here clearly. These people must have long legs and short torsos or some clever form of vertibrae. Either that or they are like the contortionists I used to see at the circus as a boy.....I would be careful what you say as some of the guys that are driving these cars are BIG guys and you may not want to call them Circus freaks to their faces...
So whats the solution?
Modify the cage? The RCR cage is not legal for competition in the UK. It does not comply with RAC MSA regs. The design lacks any diagonal bracing, which is essential for good cage performance, an issue however driven by the fact that the diagonal has to miss the crank nose...its not intended to be a race series legal cage...it is a safety measure for open track days only...But the material specs do meet the SCCA regs for a car under 2500lbs....We can build a fully legal cage but if you have concerns now then you would not have a chance in h#ll of getting into a fully legal FULLRACE cage GT40...check out Ron Earps T70 build thread for a full race cage here in the USA.
Some creative design can resolve this and fabricating your own cage is one solution, but unless you have a tube bender and a skilled hand on the MIG, its a bit of a specialist job....CORRECT...but no MIG allowed on an RCR ONLY TIG....
So getting a Safety Devices type company to make something is one option. Probably very expensive as a very low volume option however....CORRECT...but that is your trade off once again
I think the cage can be improved. Removing the horizontal tube behind the drivers head is an essential safety mod in my opinion. Increasing the cages weight by adding more tubes into the rear bulkhead is a downside, but that the only way to overcome the intrusion of the crank nose into the rear bulkead...there is no way to avoid the bump in the firewall unless you run a remote waterpump or a late model LSx Chevy engine
A more accurately curved tube above the screen will also permit an extra inch or so of vertical field of vision....so have Safety devices make one to your spec which you can oversee....as I mentioned we can certainly build you a full race cage but they are not cheap and the governing body specs the rules and dictate the tube location/placement not the owners personal preference.
Alternatively we could ask Fran to provide a lowered floor, but on the UK's roads that would be a disaster, and very prone to damage on its leading edge....there is no need...to be a GT40 driver you must accept some of the cars design issues and one of them is restricted space....as you kindly mention we do have cavernous space inside the footwells and we have MANY larger stature drivers sitting comfortably...but they accept the short comings of a small car.
The best solution however will be to redesign the seat to incorporate a curved backrest. The current upholstery does not really allow this without looking a bit of a dogs breakfast around the bolsters, so it will mean getting the covers modified, or better still convincing Fran to add a curved seat to the options inventory...we have a curved seat shell in Fiberglass and its the standard seat in our SL-C....a couple of Australian guys have tried it for size in a RCR40 and it worked for them..so problem solved...you just need to ask...ONCE MORE.
All in all I was surprised by the problems I had fitting in the car. While the footwells in the RCR are enormous, its the seating angle which has to be got right if you are going to concentrate on driving rather than neck ache....the seat angle is exactly the same as an original GT40...another design flaw in an original....
Arnie , the thing to remember also is that with an RCR the cage is a bolted in component that can be removed quite easily or built to be removed...to be more exact, and as such you can simply unbolt it when not required for road driving with no helmet and reinstated when helmet and track use is required...you are not married to it...
I hasn't put me off, but it will seemingly all add to the cost. Luckily the Dollar is moving the right way again today, so all is not lost!...so what are you waiting for........
Have you sold the Cat yet????
RCR-40..Mk1, 2 and Mk4
RCR-70 Mk3b
RCR-70 Spider
RCR-P4
Superlite Coupe
RCR917
XJ13 for SCF
www.RACECARREPLICAS.COM
www.superlitecars.com
gt40fran is offline   Reply With Quote
