| Re: Radio anyone?? Bernie
I also wanted a radio in mine, have a look at the photo here for the solution MDA came up with. You can see in the door an insert that triples as a door pull, storage area and speaker mount. These work really well and the speakers are round and approx 6 inches dia. Note also the radio mounted in a recessed notch in the dash. This radio/CD/MP3 player has a memory card (SD) slot and an USB slot so it can play solid state MP3s. I have a 4Gb SD card with all my music on that I load into the slot and hit random. I will be adding a 600W amp soon, as it is the only way to get the sound quality obove the engine noise.of course the purist will say "why do you not want to listen to the V8 soundtrack" and most times I do, but every now and then a bit of music is welcome.
Hope this helps, I think MDA have a presence in Aus although I'm not sure, search on mdagt40.com
Chris |
